Scratch plate or not ?
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=45384
Author:  Cablepuller [ Thu Mar 19, 2015 2:50 pm ]
Post subject:  Scratch plate or not ?
Hi
Just interested in any thoughts before i stick on a scratch plate on my dreadnought.
I have noticed alot of handmade guitars dont put a scratchplate on
Is this for aesthetical reasons or does it somehow affect the soundboard responsiveness
Will probably stick mine on anyway as i like the look
But just wondering
Author:  jfmckenna [ Thu Mar 19, 2015 3:09 pm ]
Post subject:  Re: Scratch plate or not ?
I think it just depends on the player. Some people are pretty hard with picks and or finger nails flailing around all over the place others are very gentle. Personally I like them and if aesthetics is an issue I just use a clear one.
Author:  meddlingfool [ Thu Mar 19, 2015 3:29 pm ]
I do, I use clear ones...
Author:  Michaeldc [ Thu Mar 19, 2015 3:49 pm ]
Clear and thin...
Author:  Clay S. [ Thu Mar 19, 2015 4:23 pm ]
On a dreadnaught I would use one. Sooner or later you will run into a "player" who likes to flail away on the guitar to show how loud he can make it. He may also be wearing an oversized belt buckle, and he may take offence when you ask him to cover or remove it.
Author:  Greg [ Thu Mar 19, 2015 5:47 pm ]
I will put one on if player wants. I like the look without
Author:  Jim Watts [ Thu Mar 19, 2015 7:42 pm ]
Clear one here too. They're almost invisible when done well.
IMO though, on a dreadnaught, I'd use a standard faux tortoise shell pickguard. It keeps with the traditional theme of the instrument.
Author:  Joe Beaver [ Thu Mar 19, 2015 8:55 pm ]
I think with the use of the super hard urethane finishes, pick guards were no longer needed. Some liked the 'new' look so a trend developed. Us who used softer finishes started using clear so we could trend along with them. I still like the look of a guard but I do tend to use clear anyway.
Author:  Tai Fu [ Fri Mar 20, 2015 1:09 am ]
I think scratch plates are still needed. I've seen the way some people pick their guitars and think that the scratch plate must go all the way to the soundhole... I've seen lots of well used guitars with damage concentrated in that area. However some players may think it will affect sound (it does, place your hand next to the soundhole when you strum, and now do it without your hand there, and there's a difference). Even placing a tuner on the side of the soundhole can affect sound as well...
Author:  Pegasusguitars [ Fri Mar 20, 2015 12:02 pm ]
I've used clear 5mm thick pick guards for a long time. With darker wood tops, like koa, they look O.K., and even not too bad on spruce. However, on redwood, I have limited success getting them to look good. Air bubbles really stand out. Are any of you floating them on with soap and water and what is your process for doing that? Interesting side note. I saw a 30 year old guitar of mine awhile back that belonged to a heavy smoker, all varieties of smoke I think. I'm convinced that the yellowing was intensified by the smoke, because my lacquer does not normally yellow that much just from age.The spruce top had become a dark yellow color , but under the clear pick guard the spruce was as white as the day it was put on. Very bizarre look!
Author:  Colin North [ Fri Mar 20, 2015 4:30 pm ]
5 mm? Maybe a typo. no?
I float my clear pickguards, pretty much like SM instructions, except I use an eraser with a tapered end instead of a squeegee.
http://www.stewmac.com/How-To/Online_Resources/Pickguards/Self-Adhesive_Clear_Mylar_Plastic.html
(I have tried it both with a tiny drop of liquid soap in the water and with the windex. Both work, don't see much difference if any, but think the windex is a better idea FWIW)
Author:  Pegasusguitars [ Sat Mar 21, 2015 2:02 am ]
Colin,
Yes, 5mm would be a bit weird! Thanks for the reply. I followed that Stew Mac link. Have not tried the Windex, but will next time. I think my wife Anne and I stopped by to see you a couple of years ago, in 2011. You were pushed for time, but spent some with us anyway. Your name is not in her journal, and I'm bad with names, but I do believe it was you. Hope all is well.
Author:  Colin North [ Sat Mar 21, 2015 2:13 am ]
Pegasusguitars wrote:
Colin,
Hi Bob, I don't think it was me.
Author:  Pegasusguitars [ Sat Mar 21, 2015 12:37 pm ]
Oh well. That visit will remain a mystery. Thanks for the responses Colin.-Bob
